PLOTTERMANAGER command
Create and edit plotter settings.
Opens a generic PlotConfig system dialog box where you can choose a plotter configuration file or where you can create and edit customized parameter PC3 files for printers and other output devices.
  • CONVERTCTB command
  • CONVERTPSTYLES command
  • PAGESETUP command
  • PLOT command
  • PLOTSTYLE command
  • PRINT command
  • STYLESMANAGER command
Related Information
  • Plotter configuration
