POINTCLOUDTRACE command
Creates 2D polylines by snapping segments to points in a point cloud.
Icon:
Creates 2D polylines, with each segment snapping to the best-fitting line through points in a point cloud.
Method
The command works in the active UCS.
Note: The command works best with a crop boundary (POINTCLOUDCROP command), a section plane view (ACTIVATESECTIONVIEW command), or Outline render mode activated (POINTCLOUDMANAGERPANELOPEN command).
Depending on the current Connect mode setting, the command creates separate single-segment polylines or one multiple-segment polyline.
Change the settings or start creating polylines.
Move the cursor over the point cloud to see a preview of the possible segments. The preview extends as far as points are detected to fit the line segment. Click to accept.
Once the first segment is created, the Hotkey Assistant widget options become available to modify the behavior setting. Press the Ctrl key to switch between the options Default fitting, Ortho override and Two-points override.
Note: The Hotkey Assistant widget is displayed if the HOTKEYASSISTANT system variable is set to 1 and the Display Hotkey Hints for POINTCLOUDTRACE options checkbox is ticked in the Hotkey Assistant Configuration dialog box (see the Hotkey Assistant widget article).
Repeat this for the next segments, then press Enter to end the command.
Options within the command
Settings
Connect
Sets the connect mode.
Connected
Creates a multiple-segment polyline. Extends the previous and current segments to connect them.
Separate
Creates single-segment polylines. The segments extend as far as points are detected.
Default
Fits line segments to visible points in point cloud.
Ortho
Defines a new line segment, perpendicular and auto-connected to the previous one.
Note: In this mode, there is no snapping to points of the point cloud.
Move the cursor to display the preview of the new segment. Click to accept it.
TwoPoints
Defines a new line segment by two points, auto-connected on one side to the previous segment.
Click the first point and move the cursor to display the preview of the new line segment. Click the second point to accept it.
Close
Closes the current polyline by connecting the first and last line segment and exits the command.
Undo
Undoes the last created line or polyline segment and continues drawing from its previous start point.
