PURGE command
PURGE command
Removes unused named entities from drawings.
Icon:
Alias: PU
Opens the Purge dialog box to select unused named entities to remove from the drawing.
Related commands
  • -PURGE command
  • EXPLORER command
  • LOAD command
Related information
  • Purge dialog box
