QLEADER command
Draws leaders through a dialog box.
Icon:
Draws leaders with a variety of annotation types and allows you to specify the properties through a dialog box.
- Start point
 - Next point
 - To point
 - Annotation
Options within the command
- Settings
 - The QLeader Settings dialog box pops up. Several settings can be specified there. See the related article QLeader Settings dialog box.
- Text width
 - Specifies the text width for the text bounding box. Enter a value or 0 if no limit on the width needs to be set.
