RECSCRIPT command
Records keystrokes in the current drawing and saves them to an SCR script file.
            Icon:
Opens the Record script dialog box where you have to choose an SCR file. After choosing Save in the dialog box, the commands and pick points you specify in the drawing editor are recorded in the SCR file until you run the STOPSCRIPT command.
Note: To run the recorded script, launch the SCRIPT command.
