SCRIPT command
SCRIPT command
Opens the Run script dialog box.
Icon:
Alias: SCR
Opens the Run script dialog box to select an SCR file to run. After choosing Open in the dialog box, the script begins running immediately. You can press the Esc key to stop it.
Related commands
  • RECSCRIPT command
  • STOPSCRIPT command
Related information
  • Recording and playing actions in BricsCAD
  • Standard Open file dialog box
