REVERSE command
Reverses the direction of selected lines, polylines, splines, and helixes.
Reverses the direction of the selected lines, polylines, splines, and helixes by swapping the start and end points.
Note: This command is helpful for linetypes that contain text. A linetype with text has the rotation angle of the characters displayed in the linetype definition. The rotation angle for the text must be prefixed with:
- U= specifies upright text orientation
- R= specifies relative or tangential rotation to the line
- A= specifies the absolute rotation of the text relative to the origin
