RTEXT command (Express Tools)
Inserts or edits a remote text entity.
Icon:
The RTEXT command can be used to add frequently used text to multiple files. The command inserts the text of a .txt file to the drawing.
Options within the command
Style
Allows you to specify the text style.
Allows you to enter the text style mask to list.
Lists all available text styles.
Height
Allows you to specify the RText height.
Rotation
Allows you to specify the rotation angle of the RText.
File
Opens the Select text file dialog box that allows you to select a .txt file.
Diesel
Opens the Edit Rtext dialog box that allows you to use a DIESEL code.
