-SECTIONDATASOURCES command
Manages the data sources inside a section line group.
Method
Specify the section line group name or accept the default section line group name, then select the section sources to add.
Options within the command
- Remove Datasources
- Allows you to select the section sources you want to remove.
- Add dAtasource
- Allows you to select the section sources you want to add.
