SECTIONDATASOURCES command
Manages the data sources inside a section line group.
Method
Specify the section line group name or accept the default section line group name.
The Manage Data Sources dialog box opens.
- Section line group
- Available data sources
- Selected data sources
Section line group
Displays the section line group name.
Lists all available data sources in the drawing.
Selected data sources can be added to the Selected data sources list by pressing the
button.
Lists the selected data sources that are included in the section line group.
Selected data sources can be removed from the Selected data sources list by pressing the
button.
Also, you can select the civil entities from the drawing, by pressing the
button.
