SETLICENSELEVEL command
Changes the available commands by setting the license type.
Runs BricsCAD and/or Communicator for BricsCAD at different license levels, which affects the commands that are available to the user. For the new license level to take effect, users must exit BricsCAD and then start it again.
Method
There are two methods to change the license level:
- Change the license level of BricsCAD.
- Change the license level of Communicator for BricsCAD.
Options within the command
- Run BricsCAD at another license level
- Lite - runs BricsCAD without 3D functionalities, except API and LISP.
- Pro - runs BricsCAD without BIM and Mechanical commands.
- Bim - runs BricsCAD with Pro and BIM commands.
- Mechanical - runs BricsCAD with Pro and Mechanical commands.
- Ultimate - runs BricsCAD with full functionalities, including BIM and Mechanical commands.
- Run Communicator at another license level
- No license - disables Communicator for BricsCAD.
- Trial - stops running Communicator for BricsCAD after 30 days.
- Full - runs Communicator for BricsCAD normally.
