USECOMMUNICATOR system variable
Use Communicator
Shows if the Communicator for BricsCAD is in use. If active, also shows the license type.
- 0: no license, Communicator for BricsCAD import and export formats are not available.
- 1: trial, runs Communicator for BricsCAD in trial mode, expiring after 30 days.
- 2: full, runs the full Communicator for BricsCAD import-export set.
If the license is changed, the new level comes into effect after restarting the program.
BricsCAD only
| Type: | Short |
| Saved in: | Preference |
| Range: |
0 to 2 |
| Default value: |
1 |
| Possible options: |
0: Not using Communicator 1: Communicator in use - on trial 2: Communicator in use - fully licensed |
