SHEETSET command
Opens the Sheet Sets panel.
Icon:
Alias: SSM
Opens the Sheet Sets panel to display it in the current workspace. The Sheet Sets panel appears at the same size and location as it did before it was closed or collapsed. Like any other dockable panel, the Sheet Sets panel can be either floating, docked or stacked.
The Sheet Sets panel offers a central location to create and to manage sheet sets.
- Current sheet set name
- Search
- Menu
- Create sheet set
- Open sheet set
- Publish
- eTransmit
- Sheet selection sets
- Custom properties
- Refresh
- Sheet list
- Category views
- Model views
- Sheet Sets list
- Details
Displays the name of the current sheet set. From the drop-down list you can change the current sheet set.
Search
Opens a search field that allows you to search for specific sheet set, subset or sheet names.
Menu
Opens a menu with a number of options depending on the sheet set panel state:
- Import from XML
- Allows you to import an XML file that was created in BricsCAD® with Export to XML.... Opens the Import Sheet Set dialog box.
- Export to XML
- Exports a sheet set in XML format. Opens the Export Sheet Set As dialog box.
- Sheet Set Options
- Opens the Sheet Controls options in the Settings dialog box.
- Custom Properties
- Allows you to add custom properties for sheet sets and sheets. Opens the Custom Properties dialog box.
Create sheet set
Opens the Create New Sheet Set dialog box.
Open sheet set
Opens the Select a Sheet Set file dialog box to select the DST file to be loaded. Click the right-side arrow to open a drop-down menu which contains a list with the recently opened DST files. Click one of these files to load the sheet set into the panel.
- Open
- Opens the selected DST file from the Select a Sheet Set file dialog box.
Publish
Publishes the currently selected sheet set(s), subset(s) or sheet(s) using the Publish dialog box. Click the right-side arrow to open a drop-down menu:
- Publish
- Publishes the currently selected sheet set(s), subset(s) or sheet(s) using the Publish dialog box.
- Publish to PDF
- Publishes the currently selected sheet set(s), subset(s) or sheet(s) to PDF using the last used presets.
- Publish to Plotter
- Publishes the currently selected sheet set(s), subset(s) or sheet(s) using a plotter based on the last used presets.
eTransmit
Launches the ETRANSMIT command. The currently selected sheet set(s), subset(s) or sheet(s) are included in the eTransmit procedure. Opens the eTransmit dialog box.
Opens the Manage Sheet Selections dialog box. Click the right-side arrow to open a drop-down menu:
- Manage...
Opens the Manage Sheet Selections dialog box where you can rename or delete Sheet selections.
- Create
- Saves the Sheet selection with a specified name.
- List of existing sheet selection sets
- Lists the existing sheet selection sets of the active (selected) sheet set in the panel. Click one of these items to activate the selection set.
Custom properties
Refresh
Updates all information stored in the sheet set data (DST) file, checks all folders in every resource location for new or removed drawing files, and all expanded drawing files for new or removed model space views.
Sheet list
Displays the Sheet Sets in the Sheet list mode.
Category view
Displays the Sheet Sets grouped by category.
Model views
- Add new location
- Folders
- Model views
- Add new location
- Opens the Browse for Folder dialog box to choose a folder to be added. Only unique folders can be added.
- Folders
- Lists all added folders that contain the drawings and their model views. The Model Views functionality allows you to browse and select model views (created with the VIEW command) from external drawings and insert them into the Paper Space layout of the current drawing, without opening the original file.
- Model views
- Model views (created with the VIEW command) from external drawings can be dragged and dropped into a Paper Space layout of the current drawing.
Sheet Sets list
Displays the current sheet set.
When you change the project name in the BIM Project Browser panel, the Sheet Set name is updated correspondingly.
A Sheet Set can contain Sheets, Subsets, and Sheet Views.
Right-click menus offer additional tools:
- Sheet Set
- Close Sheet Set
- Removes the Sheet set from the panel.
- Sheet
- Open
- Opens the drawing with the layout of the selected sheet.
- Subset
- Rename Subset
- Allows you to rename the selected subset.
- Sheet View
- Display View
- Opens the drawing file related to the selected Sheet View.
- Double-click a sheet set or a subset to expand/collapse. Double-click a Sheet or a Sheet View to open it.
- Sheet set tree nodes can be reordered using drag and drop.
- The properties and variables of a selected Sheet Set, Subset, Sheet or Sheet View are displayed in the Details section.
Details
Displays the details of the selected Sheet Set, Subset, Sheet, or Sheet View. A preview of the selected sheets or subset can be shown or hidden.
In the , the File path, View label block, Callout blocks and Total sheets options are read only, but selectable.
- Click the Browse button (
) next to View label block option to open the Select Block dialog box. - Click the Browse button (
) next to Callout blocks option to open the Blocks List dialog box.
