SHEETSETHIDE command
Closes the Sheet Sets panel.
Closes the Sheet Sets panel to hide it from the current workspace. If the Sheet Sets panel is stacked when you close it, the Sheet sets tab or icon is removed from the stack.
SHEETSETHIDE command - BricsCAD Lite & Pro | Bricsys Help Center
