SMDISSOLVE command
Removes the sheet metal data from the selected features.
                Icon:
Dissolves sheet metal feature on 3D solid faces. Dissolved features are no longer listed in the Mechanical Browser. Faces of dissolved features can be moved, rotated or push-pulled freely.
Method
There are two methods to remove sheet metal data from features:
- Select faces on model.
- Remove from the entire drawing.
