STRINGDELETEPI command
Deletes PI points (Points of intersections) from a Civil String entity.
Icon:
Method
Select the Civil String entity and specify each PI point for deleting.
Related commands
  • STRING command
  • STRINGADDCURVE command
  • STRINGADDPI command
  • STRINGADDELEVATIONPOINT command
  • STRINGDELETEELEVATIONPOINT command
  • STRINGELEVATIONFROMSURFACE command
  • STRINGFROMOBJECT command
  • TIN command
Related information
  • Civil Explorer panel
  • Create a TIN Surface
