STRINGFLATTEN command
Sets a constant slope or elevation between two selected Civil String points.
Icon:
Method
Select the Civil String entity, specify the start and end points, and choose an option to assign elevations to the points between them.
Options within the command
- Specify elevation
- Allows you to specify the elevation for the selected start or end points.
- Difference
- Allows you to specify an elevation difference between the start and end points.
- Slope
- Allows you to specify a slope (1:x) for point elevations between the start and end points.
- Grade
- Allows you to specify a percentage grade for point elevations between the start and end points.
