String Editor dialog box
Opens via:
- STRINGEDITOR command
- Civil Explorer panel > context menu of a String entity definition (Definition tab)
The String Editor dialog box allows you to edit the Civil String entities.
- Select String
- Elevations tab
- Horizontal geometry tab
- Statistics tab
Select String
Displays the Civil String for editing. You can select another Civil String from the drop-down list or click
to pick it from the drawing area.
Elevations tab
Lists all points properties of the Civil String for editing.
- Zoom
- Raise/Lower
- Add elevation point
- Get elevation from surface
- Reverse string
- Flatten grade or elevations
- Relative to surface
- Table of string points
- Zoom
- Zooms in the drawing to the selected Civil String.
- Raise/Lower
- Opens the Raise/Lower dialog box to set the elevation difference value. This value will be added to the elevations. Negative values decrease the elevation.
- Launches the STRINGADDELEVATIONPOINT command. Adds an elevation point to a Civil String entity.
- Opens the Elevations From Surface dialog box.
- Reverse string
- Changes the direction of the Civil String.
- Opens the Flatten dialog box to set a constant elevation or a constant grade between selected Civil String points.
- Displays the selected TIN surface to which a Civil String elevations will be relative. You can select another TIN surface from the drop-down list or click
- Lists all points of the selected Civil String and displays their property values.Note:
- To select point rows in the table, you can also use the Ctrl and Shift keys.
- Select one or more point rows in the table and right-click to open a context menu. Depending on the point type, the Zoom to, Pan to, Copy to clipboard, and the Delete PI (
) or Delete elevation point (
) options are available.
- To edit the Elevation, Elevation to surface, Grade back, Grade ahead, Slope back, or Slope ahead property values for one or more string points at once, select the corresponding point rows, click one cell in the property column and enter a new value.
Lists all segments properties of the Civil String for editing.
- Add PI
- Add curve
- Delete PI
- Reverse string
- String segments properties
- Add PI
- Launches the STRINGADDPI command.
- Add curve
- Launches the STRINGADDCURVE command.
- Delete PI
- Launches the STRINGDELETEPI command.
- Reverse string
- Lists all String segments properties.
Statistics tab
Lists the general properties of the Civil String.
Points intersection (PI)
Point intersection (PI) read only
Point intersection (PI) shared
Elevation Point
