-TINEXTRACT command
Extracts meshes, solids, points, faces, contours or borders from a TIN surface via Command line.
Creates a mesh or 3D solid between two TIN surfaces or between a TIN surface and elevation or vertical offset.
Method
Select a TIN surface and choose which entity want to extract or create.
Options within the command
Mesh
Creates a mesh as an offset, between surfaces or as an elevation:
vertical offset
Creates a mesh as a vertical offset above the TIN surface.
between Surfaces
Creates a mesh between two TIN surfaces.
Elevation
Creates a mesh vertically from a TIN surface to a fixed elevation height.
Separate cut and fill
If YES, it creates separate meshes for cut and fill.
Solid
Creates a solid as an offset between surfaces or as an elevation.
vertical offset
Creates a solid as a vertical offset above the TIN surface.
between Surfaces
Creates a solid between the TIN surfaces.
Elevation
Creates a solid vertically from a TIN surface to a fixed elevation height.
If YES, it creates separate solids for cut and fill.
Points
Extracts all points on the surface.
Faces
Extracts all triangular faces of the surface.
Contours
Extracts the contours of the surfaces for an elevation.
Minor
Extracts the contours of the surfaces for an elevation according to minor contours interval set in TIN surface properties panel.
maJor
Extracts the contours of the surfaces for an elevation according to major contours interval set in TIN surface properties panel.
All
Creates contours for all elevations.
Border
Extracts the outer boundary of the surface.
Intersections
Extracts 3D Polylines at the intersection between two TIN surfaces.
