TINEXTRACT command
Extract entities from a TIN surface.
Icon:
Opens the Extract from TIN Surface dialog box to choose which entity you want to extract from a TIN surface.
Major contours
Extracts the contours of the TIN surfaces for an elevation according to major contours interval set.
Layer
Sets the layer where the major contours will be placed.
Interval
Defines the major contours interval.
Minor contours
Extracts the contours of the TIN surfaces for an elevation according to minor contours interval set.
Layer
Sets the layer where the minor contours will be placed.
Interval
Defines the minor contours interval.
Points
Extracts all points on the surface.
Layer
Sets the layer where the points will be placed.
Triangles
Extracts all triangular faces of the surface.
Layer
Sets the layer where the triangular faces will be placed.
Borders
Extracts the outer boundary of the surface.
Layer
Sets the layer where the outer boundary will be placed.
