TCONNECT command
Connects solid faces and edges of planar surfaces to other solids, planar surfaces or regions.
Icons:
Connects the selected solid faces or edges of the planar surfaces to other solid faces, planar surfaces or regions.
Step1 | Step2 | Step3 |
Note: If the KEEPCONNECTIONS system variable is ON, the connected solid is subtracted from interfering solids.
Options within the command
- Connect to nearest
- Connects the selected face(s) or edges of planar surfaces to the nearest regions, planar surfaces or face(s) of other solid(s).
- Disconnect
- This option applies to solid faces only. The face is disconnected and made perpendicular to the adjacent faces, which results in a single edge or vertex connection.
- Connect
- Switch to the connect face mode.
