TEXTMASK command (Express Tools)
Creates a mask behind the selected text or mtext entities.
Icon:
Method
Creates a mask entity behind the selected text or mtext entities, by specifying the mask type and the offset value.
Note: Use the TEXTUNMASK command to remove the mask from the text.
Options within the command
Masktype
Allows you to set the mask type.
Wipeout
Creates a wipeout entity, displayed in the background color of the drawing.
3d face
Creates a 3D face entity.
Solid
Creates a 2D solid entity, using a specified color.
Opens the Color dialog box which allows you to select the color.
Offset
Allows you to define an offset distance.
