TINEXTRACT command
Extract entities from TIN surface to which creates a mesh or 3D solid between TIN surfaces or between a TIN surface and elevation or vertical offset.
Icon:
Creates a mesh or 3D solid between two TIN surfaces or between a TIN surface and elevation or vertical offset.
Select a TIN surface and choose which entity want to extract or create.
Options within the command
- Mesh
- Creates a mesh as an offset, between surfaces or as an elevation:
- Solid
- Creates a solid as an offset, between surfaces or as an elevation.
- Points
- Extracts all points on the surface.
- Faces
- Extracts all triangular faces of the surface.
- Contours
- Extracts the contours of the surfaces for an elevation.
- Border
- Extracts the outer boundary of the surface.
- Intersections
- Extracts 3D Polylines at the intersection between two TIN surfaces.
