TINFROMDEM command
Creates a TIN surface using points from a DEM (Digital Elevation Model) grid.
Icon:
Method
Opens the Select a DEM format dialog box to choose a DEM (Digital Elevation Model) file format.
The available DEM (Digital Elevation Model) file format are:
- GeoTIFF (.tiff)
- USGS Digital Elevation Model (.dem)
- ESRI Arc/Info Binary Grid (.adf)
- ESRI ASCII Grid (.asc)
After selecting the file, you can downsample the grid.
Options within the command
- Would you like to subsample from grid [820,620] spacing (2.000) units to grid [410,310] spacing (4.000) units?
- Allows you to decide whether to keep the original grid spacing.
