TRIM command
Trims entities by a cutting line.
Icon:
Alias: TR
Method
There are two methods:
- Trims entities.
- Extends entities while holding down the Shift key.
Note: The following entities can be trimmed: lines, two and three dimensional polylines, arcs, circles, ellipses, elliptical arcs, splines, rays and infinite lines.
Note: Cutting entities can be: lines, splines, polylines, arcs, circles, elliptical arcs, ellipses, rays, infinite lines, layout viewports.
Options within the command
- Fence
- Trims all entities that cross the selection fence. The selection fence is a series of temporary line segments. The selection fence does not form a closed loop.
- Crossing
- Trims entities within and crossing a rectangular area defined by two points.
- Edge mode
- Toggles between Extend and No extend.
- Projection
- Specifies the projection method used when extending objects.
- eRase
- Deletes the selected entity.
- Undo
- Undoes the last trim action.
