WMFOUT command
Saves data from the current drawing to a WMF/SLD/EMF file.
![BricsCAD Lite; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM](https://static.bricsys.com/help/images/V25/en_INTL/command-reference-lite-pro-mechanical-bim.png)
Alias: WO
Method
Opens the Create WMF file dialog box to save data from the current drawing to the selected file format.
Select the entities you want to export.
Alias: WO
