WMFIN command
Imports data from a WMF/EMF file into the current drawing.
Alias: WI
Method
Opens the Select WMF/EMF file dialog box to import data from the selected file into the current drawing.
Options within the command
Specify insertion point
Allows you to choose the insertion point. You can also define it by picking the point in the drawing area.
Specify X scale
Allows you to set the X scale value.
Specify Y scale
Allows you to set the Y scale value.
Specify rotation
Allows you to set Z rotation value. You can also define it by picking the angle in the drawing area.
