WORKPLANEACTIVATE command (Experimental)
Activates a Work Plane.
BricsCAD Shape; BricsCAD Pro; BricsCAD Mechanical; BricsCAD BIM
Alias: ACTIVATEWORKPLANE
Disclaimer
Work Plane is an experimental feature which may not yet be stable, and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD®.
Method
Select a Work Plane in the drawing or type its name in the command line to activate it so you can draw a sketch (2D entities) on it.
Note: Work Planes can be created using the WORKPLANECREATE command.
Options within the command
Deactivate
Deactivates the Work Plane.
Note: A warning message appears if no Work Plane is active.
Name
Specifies the name of the Work Plane to be activated. Note: A warning message appears when attempting to activate another Work Plane while one is already active.
