Add Scale dialog box
Opens via:
- Default Scale List dialog box
- Edit Scale List dialog box
The Add Scale dialog box allows you to add a new scale factor to the list.
- Scale name
- Scale properties
Scale name
Specifies the scale name as it will appear in the scale list.
Scale properties
Specifies the scale factor in paper (size when plotted) and drawing units.
