Block Convert dialog box
The Block Convert dialog box allows you to select the AutoCAD® Dynamic Blocks in the current drawing to be converted to BricsCAD Parametric Blocks.
Note: This feature is in Beta / Experimental mode. Not all dynamic blocks might be properly reconstructed as parametric blocks.
- List of blocks
- Preview
- Details for
- Output options
- Block name suffix
- List of blocks
- All AutoCAD® Dynamic blocks that are present in the current drawing are listed here. Individually check the blocks you want to convert to BricsCAD Parametric Blocks or check all by ticking the Select all option.Note: Blocks that cannot be converted or can be partially converted are marked with a red or yellow warning sign respectively.
- Preview
- Displays a preview of the currently selected block in the list.
- Details for
- Displays information on whether the selected block can be converted or not. If the block cannot be converted, the features that are not supported are listed.
- Output options
- Convert blocks to this file
- Converts the dynamic blocks into the parametric blocks inside the current file.
- Block name suffix
- Allows you to modify the default block name suffix. The last used name for suffix is remembered.
