Choose Window Style dialog box
Opens via: BIMWINDOWCREATE command
The Choose Window Style dialog box allows you to specify the style of a window.
A series of parameters is created, which can be edited in the Parameters section of the Properties panel. Rectangular windows and openings have a W (Width) and H (Height) parameter.
