Classify As Bim Element dialog box
Opens via: BIMCLASSIFY command
The Classify As Bim Element dialog box specifies the types of classification or converts the selection to a block and classifies the block reference. The dialog box opens when the Other option in the BIMCLASSIFY command is selected.
- Search bar
- Element categories
- Selected category elements
- Convert to block and classify the block reference
- Block name
- Search bar
- Allows you to search for an element in all listed element categories.
- Displays all available element categories:
- Building Core Elements
- Building Architectural Elements
- Building Structural Elements
- Building Control Elements
- Building Service Elements
- Electrical Elements
- HVAC Elements
- Plumbing & Fire Protection Elements
- Spatial Structure Elements
- Civil Elements
- Generic Elements
- Displays all the elements available for the selected category.
Note: To have access to element properties but not classify an entity as a specific element type, choose the Building Element type from the Generic Elements category for the that entity.
- Converts the selection to a block that is then classified as the selected element. Selecting it enables the Block name field.
- Block name
- Allows you to enter a name for the soon to be created block reference.
Note: All element types can be exported and imported to IFC4x3, and can be used in data extraction, filtering (for Typed Plans or Graphic Override).
Note: Information about each element type can be found here.
- Beam
- Chimney
- Column
- Curtain Wall
- Member
- Opening
- Railing
- Ramp
- Ramp Flight
- Roof
- Slab
- Slab Elemented Case
- Stair
- Stair Flight
- Transport Element
- Wall
- Wall Elemented Case
- Covering
- Door
- Furnishing Element
- Furniture
- Shading Device
- System Furniture Element
- Window
- Caisson Foundation
- Deep Foundation
- Discrete Accessory
- Fastener
- Footing
- Mechanical Fastener
- Pile
- Plate
- Reinforcing Bar
- Reinforcing Mesh
- Tendon
- Tendon Anchor
- Tendon Conduit
- Actuator
- Alarm
- Controller
- Flow Instrument
- Sensor
- Unitary Control Element
- Conveyor Segment
- Distribution Chamber Element
- Distribution Control Element
- Distribution Element
- Distribution Flow Element
- Distribution Port
- Energy Conversion Device
- Equipment Element
- Flow Connection Point
- Flow Controller
- Flow Fitting
- Flow Moving Device
- Flow Segment
- Flow Storage Device
- Flow Terminal
- Flow Treatment Device
Electrical Elements
- Audio-Visual Appliance
- Cable Carrier Fitting
- Cable Fitting
- Cable Segment
- Communications Appliance
- Electric Appliance
- Electric Distribution Board
- Electric Distribution Point
- Electric Flow Storage Device
- Electric Flow Treatment Device
- Electric Generator
- Electric Motor
- Electric Time Control
- Electric Element
- Junction Box
- Lamp
- Light Fixture
- Mobile Telecommunications Appliance
- Motor Connection
- Outlet
- Protective Device
- Protective Device Tripping Unit
- Solar Device
- Switching Device
- Transformer
HVAC Elements
- Air Terminal
- Air Terminal Box
- Air-To-Air Heat Recovery
- Boiler
- Burner
- Chiller
- Coil
- Compressor
- Condenser
- Cooled Beam
- Cooling Tower
- Damper
- Duct Fitting
- Duct Segment
- Duct Silencer
- Engine
- Evaporative Cooler
- Evaporator
- Fan
- Filter
- Flow Meter
- Heat Exchanger
- Humidifier
- Medical Device
- Pipe Fitting
- Pipe Segment
- Pump
- Space Heater
- Tank
- Tube Bundle
- Unitary Equipment
- Valve
- Vibration Isolator
- Fire Suppression Terminal
- Interceptor
- Sanitary Terminal
- Stack Terminal
- Waste Terminal
- Building
- Site
- Space
- Story
Civil Elements
- Alignment
- Alignment Cant
- Alignment Horizontal
- Alignment Segment
- Alignment Vertical
- Bearing
- Borehole
- Civil Element
- Course
- Earthworks Element
- Earthworks Fill
- Geographic Element
- Geomodel
- Geoslice
- Geothechnical Stratum
- Kerb
- Linear Element
- Liquid Terminal
- Mooring Device
- Navigation Element
- Pavement
- Rail
- Referent
- Reinforced Soil
- Sign
- Signal
- Track Element
Generic Elements
- Annotation
- BIM XReference
- Building Element
- Building Element Part
- Building Element Proxy
- Element Assembly
- Grid
- Grid Axis
- Impact Protection Device
- Proxy
- Vehicle
- Vibration Damper
- Virtual Element
