Create New Drawing dialog box
Opens via:
  • NEWWIZ command
  • Start page > Click the right-side arrow next to the New drawing button > Start new drawing wizard...
    Note: To display the Create New Drawing dialog box from the Start page, the STARTUP system variable must be set to 2, 3 or 4.
The Create New Drawing dialog box offers multiple methods to create new drawings through The New Drawing wizard.
Load Working Set
Opens all drawings from a previously saved working set.
Load Last Session
Reopens all drawings that were open when the last BricsCAD session was closed. The names of all open drawings are saved automatically as a working set named LastSession when BricsCAD is closed.
Load Working Set
Opens a previously saved working set.
Note: The Load Working Set option is available only when the Create New Drawing dialog box is opened from the Start page.
Open Drawing(s)
Opens the Open drawing dialog box, where one or more drawing files can be selected and opened.
Note: The Open Drawing(s) option is available only when the Create New Drawing dialog box is opened from the Start page.
Start from Scratch
Creates a new drawing using the imperial or metric default settings.
Imperial (feet and inches)
Creates a new drawing based on the default-imperial.dwt template file, which uses imperial units.
Metric
Creates a new drawing based on the default-mm.dwt template file, which uses metric units.
Start from Template
Starts the new drawing based on a copy of the selected drawing template.
Select a Template
Specifies the DWT template file for the new drawing, selected from the template list.
The templates are stored in the folder specified by the TEMPLATEPATH system variable. The default location is: C:\Users\%username%\AppData\Local\Bricsys\BricsCAD\V27x64\en_US\Templates\.
Use the selected template as default
Sets the selected file as the default template for new drawings. The BASEFILE system variable is updated accordingly.
Browse…
Opens the Select a template file dialog box, to select a file from the available formats (DWG, DWT, or DXF) and set it as the default template for new drawings.
Start from Default Template
Starts a new drawing using the default template specified by the BASEFILE system variable.
Note:
  • If no file is specified in the BASEFILE system variable, this option is not available in the Create New Drawing dialog box.
  • If the template specified in the BASEFILE system variable is not found in the folder specified by the TEMPLATEPATH system variable, this option uses the default drawing template instead.
Use a Wizard
Creates a new drawing based on the specified settings, including measurement units, angle type, plot configuration type and other basic drawing settings.
Metric
Unit of measurement
Sets the unit type used for linear measurements. This setting is controlled by the LUNITS system variable.
Unit Name Measures Example Display
Scientific Units, decimal units, exponents 2.1284E+03
Decimal (default) Units and decimal units 2128.4449
Engineering Feet, inches, decimal inches 4'-6.0625"
Architectural Feet, inches, fractional inches 4'-6 1/16"
Fractional Inches, fractional inches 54 1/6"
Precision
Sets the number of decimal places or the fractional precision used to display linear measurements. This setting is controlled by the LUPREC system variable.
Note: This option only controls how values are displayed. The program always performs calculations to eight decimal places.
Note: If unsure, use the Decimal unit and the default precision. The linear unit of measurement and display precision can be changed later using the UNITS command.
Angle of measurement
Sets the unit type used to enter and display angles in the drawing. This setting is controlled by the AUNITS system variable.
Angle Name Measures In Example
Decimal Degrees Degrees and decimals 12.3456
Degrees/Minutes/Sec Degrees, minutes, seconds, decimal secs 12d34'56"
Grads Grads and decimals 123.45g
Radians Radians and decimals 1.23r
Surveyor’s Units North/South degrees towards East/West N12d34'56"E
Precision
Sets the number of decimal places used to display angles in the drawing. This setting is controlled by the AUPREC system variable.
Note: If unsure, use the Decimal Degrees angle and the default precision. The angular unit of measurement and display precision can be changed later using the UNITS command.
Plot Style
Specifies the type of plot style table the drawing uses for plotting.
Color Dependent (CTB)
Assigns plot settings based on the color of each entity. Entities of the same color cannot be plotted differently.
Named (STB)
Assigns plot settings through named plot styles attached to entities or layers. Entities of the same color can be plotted differently.
Note: If unsure, select Color Dependent (CTB).
Entity
Specifies the default color and linetype for new entities, and the display settings for the drawing.
Color
Sets the default color for new entities.
Linetype
Sets the default linetype for new entities.
Grid On
Displays a grid of dots or lines that shows the unit spacing and the drawing extents.
Snap On
Sets the cursor movement to fixed increments.
UCS icon
Displays the UCS icon, which shows the orientation of the X, Y and Z axes.
Marker Blips
Draws a small + mark each time a point is specified in the drawing.
Note:
  • For Color and Linetype it is recommended to set both to ByLayer, so each entity inherits its color and linetype from its layer.
  • For Grid On and Snap On it is recommended to keep both options ticked.
  • For UCS icon it is recommended to keep this option ticked when working with 3D drawings and unticked when working with 2D drawings.
  • For Marker Blips it is recommended to keep this option unticked, as the markers can clutter the drawing area.
