Create New Sheet Set dialog box
Opens via:
- NEWSHEETSET command
- Sheet Sets panel
The Create New Sheet Set dialog box provides 4 methods to create a new sheet set.
- Use template
- Use another sheet set
- Use existing drawings
- Empty
Use template
- Use template
- Creates a new sheet set from a template.
Sheet set templates are stored as DST files in the folder set by the SheetSetTemplatePath preference (default path C:\Users\%username%\AppData\Local\Bricsys\BricsCAD\V[Version]\en_US\Templates\)
- Select a template sheet set from the list shown in the dialog box.Note: All metric projects use by default a sheet set template in mm, and will honor the setting of the SECTIONSHEETSETTEMPLATEMETRIC system variable, if not empty. The cm and meter sheet set and sheet template files are no longer included in the installation.
- Click Next.
- Specify Sheet Set file path and name
- Type a name for the sheet set file.
- Click Browse to choose a destination folder in which to save the sheet set and save it.Note: By default, the current drawing's location folder is open.
- Description
- (Optional) Type a description for the sheet set file.
- Click Next.
- Sheet Set Preview
- Review the summary of the sheet set that will be created, then click Finish to create the new sheet set file. The program opens the Sheet Sets panel with the new sheet set.
Creates a new sheet set from the settings in an existing sheet set.
- Select sheetset to copy
- Click Browse and select an existing sheet set file from the Select a Sheet Set file dialog box.
- Click Next.
- Click Browse to choose a destination folder for the sheet set and save it.
Important: You cannot progress until you have selected a folder that stores the new file.
- Description
- Click Next.
- Sheet Set Preview
- Review the summary of the sheet set that will be created, then click Finish to create the new sheet set file. The program opens the Sheet Set panel with the new sheet set.
Creates a new sheet set from an existing set of drawings.
- Select Use existing drawings.
- Click Next.
- Select Folder
- Select a folder from the Choose a folder dialog box where the new sheet set will be stored.Note: The dialog box fills with names of drawings and their layouts.
- Choose the options (it is recommended to keep both options turned on).
- Create subsets from folder structure
- Uses the folders in the main folder to determine how the sheet set is structured.
- Prefix sheet titles with drawing file names
- Add the drawing file's name to the start of the sheet set titles. This makes it easier to track the source of the files.
- Click Next.
- Click Browse to choose a destination folder for the sheet set and save it.Important: You can not progress until you select a folder.
- Description
- Default drawing template for new sheets
- Select a drawing template to be used as the default template when creating new sheets in the sheet set.
- Click Next.
- Sheet Set Preview
Empty
Creates a new sheet set from scratch.
- Select Empty.
- Click Next.
- Description
- Click Next.
- Sheet Set Preview
