Create Section/Elevation dialog box
The Create Section/Elevation dialog box saves section planes as blocks inserted in the current drawing or saved to disk as DWG files.
- Destination
- Source geometry
- Section plane
- Section type
Destination
Defines where the block will be placed in the drawing.
- Insert new block
- Inserts the created section as a new block in the drawing. The insertion point, scale and rotation can be specified.
- Insertion point
- Allows to specify the insertion point in the model space after you click the OK button, if the Specify on-screen button is checked.
- X/Y/Z
- Defines the coordinates where the block should be inserted, only available if the Specify on-screen button is checked off.
- Scale
- Allows to specify the scale factor in the model space after you click the OK button, if the Specify on-screen button is checked.
- X/Y/Z
- Defines the individual X,Y,Z direction scale factors, only available if the Specify on-screen button is checked off.
- Rotation
- Allows to specify the rotation angle in the model space after you click the OK button, if the Specify on-screen button is checked.
- Angle
- Defines the rotation angle of the inserted section/elevation.
- Replace existing block
- Replaces an existing block in the drawing. This block will be replaced by the created section
- Select
- Allows to select the block to replace in the model space.
- Export to file
Opens the Select export file dialog box. Here you can select a file to export the created section to.
Source geometry
Specifies the entities that will be included from the drawing.
- Include all entities
- Selects all 3D geometry in the drawing (includes 3D solids, 3D surfaces, polyface meshes, and 3D faces).
- Select entities
- Allows to select the entities to be included in the model space.
Section plane
Selects the section plane to be converted to a block.
Section type
Determines the kind of section plane block to create.
- 2D cross section/elevation
- Uses the 2D section settings defined by the SectionPlaneSettings dialog box to create the block.
- 3D cutaway section
- Uses the 3D section settings defined by the SectionPlaneSettings dialog box to create the block.
