Create Section Line Group dialog box
Opens via:
- SECTIONLINES command
- Create Section Lines dialog box > Section line group option > right-side three dots
The Create Section Line Group dialog box allows you to create a section line group.
- Section line group name
- Data sources
- Allows you to define a section line group name.
- Data sources
- Allows you to select the data sources that will be displayed in the section views. You can select or deselect all data sources at once or select (
) them in the drawing.
