Edit Custom Properties dialog box
Opens via: BIM Project Info dialog box
The Edit Custom Properties dialog box allows you to add custom properties to materials and compositions.
- In project
- Add Generic/ Material/Composition/Delete properties
In project
Displays the custom properties available in the project.
Add/Delete Properties
- Add Generic Custom Property
- Creates a new generic custom property, which can be assigned to building elements in the project.
- Add Material Custom Property
- Creates a new material custom property, which can be assigned to materials in the project.
- Add Composition Custom Property
- Creates a new composition custom property, which can be assigned to compositions in the project.
- Delete
- Deletes the selected property.
