Edit Dimensioning dialog box
Opens via: AMPOWEREDIT command
The Edit Dimensioning dialog box manages the properties of a dimension.
General
Dimension text box
Defines the dimension text string, including dimension value placeholders and special characters.
Representation
Defines the format of the dimension text and its appearance in the drawing.
Note: A tooltip explaining each representation appears when you hover over the option checkboxes.
Text
Adds text elements to the displayed dimension text.
Dimension value placeholders
Displays the placeholders for the dimension value in the Dimension text box. Click the icon to hide the placeholders from the text string and to hide the dimension value from the drawing.
Special Characters
Opens the Special Characters dialog box to add special characters in the dimension text string.
Value
Specifies the settings of the selected value.
Exact Distance
Displays the exact value of the selected dimension.
Precision
Specifies the number of decimal digits displayed.
Linear Scale
Specifies the linear scale of the dimension value. By default this is set to 1.
Properties
Copies dimension properties to or from the selected dimension.
Apply to
Applies
Copy From
Copies
  • Apply to: allows you to apply the specified properties to other entities. Click the Apply to button, then select the entities you want to apply the dimension settings to. The Properties dialog box opens, where you can select the properties that you want to apply to the selected entities.
  • Copy From: allows you to copy properties from a selected entity to the Edit Dimensioning dialog box. click the Copy From button and select an entity you want to copy properties from. This opens the Properties dialog box, where you can select the properties that you want to copy to the Edit Dimensioning dialog box.
Inspection
Shape
Defines the shape of the frame around the dimension text.
Round
Surrounds the text in a round shape.
Angular
Surrounds the text in an angular shape
None
Removes any shape surrounding the text.
Label/Inspection Rate
Specifies the settings for the inspection dimension.
Label
Defines the label of the dimension. Check the box to display the label.
Inspection rate
Defines rate of the inspection. Check the box to display the rate.
Note: The inspection rate is expressed as a percentage.
Geometry
Geometry
Displays a preview of the dimension. You can click any elements on the preview to turn them on or off.
Click the arrowheads to open the Arrowhead dialog box to select the type of arrowhead displayed from the drop-down list.
Text offset
Specifies the text offset from the dimension line.
Center Mark
Specifies the size of the center mark.
Note: This option is available only for radius or diameter dimensions.
Units
Primary
Specifies the properties for the primary units.
Units
Sets the unit type from the drop-down list.
Round off
Sets the number of decimals to round off the dimension values.
Alternate
Specifies the properties for alternate units.
Precision
Sets the numbers of decimals for the alternate units.
Fit
Fit
Sets the symbol to display the fit. Click the browse button () to open the Fits dialog box to select a symbol.
Precision
Specifies the number of decimals used to display the units.
Primary
Sets the number of decimals for the primary units.
Alternate
Sets the number of decimals for the alternate units.
Use Fit
Displays the fit values next to the dimension text when checked.
Preview
Displays a preview of the fit. Click to open the Fit Representation dialog box to change the representation of the fit.
Deviation
Deviation
Specifies the deviation limits between the nominal values and the tolerance values.
Upper
Sets the upper deviation limit.
Lower
Sets the lower deviation limit.
Precision
Primary
Alternate
Use Tolerance
Displays the tolerance values next to the dimension text when checked.
Preview
Displays a preview of the fit. Click to open the Tolerance Method dialog box to change the method of the tolerance.
