Extract Attributes dialog box
Opens via: ATTEXT command
The Extract Attributes dialog box allows you to export data from block attributes to a text file.
- Select
- Format of Extracted Text File
- Template File
- Output File
Select
Specifies the set of blocks with attributes to copy data from.
Note: If blocks without attributes are selected, BricsCAD® ignores them.
Specifies the format of the extracted text file. Several formats are available:
CDF: Comma Delimited Format
SDF: Space Delimited Format
DXX: DXF Format Extract File
DXF: Drawing Exchange Format
Template File
Specifies the location path of the template file by entering the path or through the Attribute Extract Template File dialog box after pressing the Browse... button.
Output File
Specifies the location path of the output file by entering the path or through the Attribute Extract Output File dialog box after pressing the Browse... button.
Extract
Exports the attribute values to the output file.
