Extract from dialog box
Opens via: TINEXTRACT command
Depending on the selected entity (TIN surface, Grading, or TIN Volume Surface), the TINEXTRACT command opens the Extract from TIN Surface / Grading / TIN Volume Surface dialog box.
Major contours
Extracts the contours of a TIN surface, Grading, or TIN Volume Surface for an elevation according to major contours interval set.
Layer
Sets the layer for the extracted major contours.
Interval
Defines the major contours interval.
Minor contours
Extracts the contours of a TIN surface, Grading, or TIN Volume Surface for an elevation according to minor contours interval set.
Layer
Sets the layer for the extracted minor contours.
Interval
Defines the minor contours interval.
User-defined contours
Extracts an user-defined contour.
Layer
Sets the layer for the extracted user-defined contours.
Elevation
Defines the elevation value.
Note: To set the elevation from the drawing area, click the Pick contour button.
Points
Extracts all points on the surface.
Layer
Sets the layer for the extracted points.
Triangles
Extracts all triangular faces of the surface.
Layer
Sets the layer for the extracted triangular faces.
Borders
Extracts the outer boundary of the surface.
Layer
Sets the layer for the extracted outer boundary.
Intersection lines between surfaces
Extracts intersection lines between the selected surfaces.
Second surface
Allows you to select one of the available surfaces in the drawing from the drop down list.
Note: You can also select the surface from the drawing area.
Layer
Sets the layer for the extracted intersection lines.
Solids/Meshes
Extracts solids or meshes between the selected surfaces.
Between surfaces
Vertical offset
Defines the vertical offset value.
Elevation
Extract As
Sets the type of the extracted entity, solid or mesh.
Layer
Sets the layer for the extracted solids or meshes.
Separate cut and fill
Toggles the creation of separate meshes for cutting and filling.
