Format dialog box
The Format dialog box allows you to specify the format of text strings in the specified column of a BOM table. It opens when you select the Format option from the BOM Manager panel.
Component
Specifies a component.
Format
Specifies the desired format for the selected component from the list.
Format code
Changes depending on the format type you choose for all the materials in the BOM table.
