Frame Settings dialog box
Opens via: Create Section View dialog box > Frame settings button
The Frame settings dialog box allows you to adjust the frame dimensions of section views.
- Width
- Height
Width
Allows you to set the width of the section view frame.
- Automatic
- Automatically sets the left and right widths.
- Fixed
- Allows you to manually specify the left and right width values.
Height
Allows you to set the height of the section view frame.
- Automatic
- Automatically sets the minimum and maximum elevations.
- Fixed
- Allows you to manually enter a specific height value.
