Frame Settings dialog box
Opens via: Create Section View dialog box > Frame settings button
The Frame settings dialog box allows you to adjust the frame dimensions of section views.
Width
Sets the width of the section view frame.
Automatic
Automatically sets the width.
Fixed
Allows you to manually specify the width value.
Height
Sets the height of the section view frame.
Automatic
Automatically sets the minimum and maximum elevations.
Fixed
Allows you to manually specify the minimum and maximum elevation values.
