Interface Settings dialog box
Opens via: Ribbon panel
The Interface Settings dialog box allows you to manage the interface display of your BricsCAD workspace.
Click the Interface Settings button to open the Interface Settings dialog box.
The Interface Settings button is located at the top-right corner of the Ribbon. The RIBBONSETTINGSENABLED system variable controls whether the button is displayed or not.
- Ribbon
- Theme
- Panel system
- General
- Customize
Ribbon
Defines the displaying mode of the ribbon.
- Labels
- Displays ribbon labels.
- No labels
- Hides ribbon labels.
Theme
Defines the color theme of the interface.
- Dark
- Sets the interface theme to dark.
- Light
- Sets the interface theme to light.
Panel System
Defines how panels should be displayed when open.
- Docked
- Organizes the panels in a docked way, reducing the model space depending on the width of the selected panel.
- Floating
- Organizes the panels in a floating way. The model space is not reduced in width as panels are floating above.
- Tabbed
- Organizes the panels in a tabbed way on both sides of the screen.
General
Allows you to toggle on and off several interface components:
- Show Status Bar
- Show Menu Bar
Customize
Displays the Customize dialog box which allows you to customize the interface to own preferences in a more detailed way.
