New Sheet(s) dialog box
The New Sheet(s) dialog box allows you to create (a) new sheet(s) within an existing sheet set. You can open it by right-clicking on a sheetset, subset or sheet in the Sheet Set Manager panel and selecting New Sheet(s)... from the context menu.
There are two methods to add new sheet(s):
_AddnewSheets_V23.png)
- Create from scratch, add new drawing
- Import layouts from existing drawings
Allows you to create a new sheet from scratch.
_FromScratch_V23.png)
- Number
- Title
- File name
- Folder path
- Template
- Add Sheet
- Number
- Defines the numbering of the created sheets.
- Prefix: specifies the prefix of the file name
- Number from: specifies the start of the numbering of the file name
- Leading zeroes: specifies how the Number value of new sheets is formatted by adding zeroes at the start of a sheet number.
- Title
- Defines the title of the new sheet(s).
- File name
- Defines the name of the file in which the new sheet(s) will be saved.
- Folder path
- Defines the location of the file.
- Template
- Defines the template of the new sheet(s).
- Add Sheet
- Creates a new sheet.Note: This option is only enabled once the title is defined.
Allows you to create a new sheet by importing layouts of existing drawings.
_ImportLayouts.png)
- Add drawing(s)…
- Imported layouts
- Number
- Automatic numbering
- Sheet titles
- Add Sheet
- Add drawing(s)...
- Selects drawings to import layouts from through the Select Drawing(s) dialog box.
- Imported layouts
- Lists the layouts that will be imported from the selected drawing. Untick the layouts that should not be imported.Note: When importing layouts from a drawing that is not part of the project, the drawing is first copied to the project folder.
- Number
- Defines the numbering of the imported sheets.
- Numbers the layouts automatically.
- Sheet titles
- Specifies how the selected drawing should be listed by selecting one of the options in the drop-down list.
- Add Sheet
- The new sheet(s) are created.
