Settings dialog box (new)
Opens via:
  • SETTINGS command
  • SETTINGSSEARCH command
In the Settings dialog box, you can change values of system variables and user preferences.
Note: The new Settings dialog box is set as default. To change this, set the value of the USENEWSETTINGSDIALOG system variable to 0.
Search bar
Lists variables through a real-time search field when entering letters of their names or descriptions.
ESSENTIAL SETTINGS
Lists frequently used settings grouped under categories.
Click a category to display the corresponding settings or subcategories. If subcategories are present, click one to display the corresponding settings.
Note: The available settings categories depend on the BricsCAD® license level.
ALL SETTINGS
Lists settings in the Complete tree view category.
All settings
Lists all settings in a tree view.
Modified settings
Lists all settings whose values ​​are different from the default marked with a blue bullet.
Click a setting to display the setting info at the bottom of the dialog box.
To revert the value of a modified setting to default, press the Revert setting to default value () button next to the setting value field.
To revert the values of all modified settings to default, press the Revert all settings to default button.
Export
Opens the Export Settings dialog box to save all settings and values to an CSV file.
Note: Settings that are stored in the drawing will not be exported.
