Slope Analysis dialog box
Opens via: (only for selected TIN surface entities) Civil Explorer panel > Visual Styles tab > TIN Analysis section > Slope analysis > click the right side three dots
The Slope Analysis dialog box allows you to define parameters for creating the TIN surface Slope Analysis
- Options
- Color scheme
- Insert legend
Options
Allows you to specify the parameters for creating the TIN surface Slope Analysis.
- Color Scheme
- Allows you to select the color scheme for the Slopes Analysis.
Choose between the available options:
- Spectrum
- Earth
- Hydro
- Gray
- Reds
- Greens
- Blues
- Custom
- DisplayAs
- Select the TIN Surface elements used to create the Slopes Analysis.
- Number of ranges
- Specifies the number of ranges for the Slope Analysis.
Color scheme
Displays the corresponding colors for slopes based on the selected color scheme.
Note: You can edit the slope values in the table.
Insert legend
Inserts the color scheme table at a specified location in the drawing.
