Surface Texture Settings dialog box
Opens via: Surface Texture dialog box > Settings... button
The Surface Texture Settings dialog box defines the leader and text properties for all surface texture symbols in the drawing, overriding those set in the Standard Settings dialog box.
Note: The default text, leader and symbol properties for all symbol annotations are defined in the Standard Settings dialog box.
Leader
Defines the leader properties for the surface texture symbol.
Arrowhead
Sets the leader arrowhead type for the surface texture symbol from the drop-down list.
Size
Sets the leader size for the surface texture symbol from the drop-down list.
Color
Sets the leader color for the surface texture symbol from the drop-down list.
Text
Defines the text properties for the surface texture symbol.
Height
Sets the text height for the surface texture symbol from the drop-down list.
Color
Sets the text color for the surface texture symbol from the drop-down list.
