Symbol Style dialog box
Opens via: Civil Explorer panel > Settings tab
The Symbol Style dialog box allows you to define a new symbol style.
- Info
- Symbol
- Display
Info
Specifies general information of the selected symbol style.
- Name
- Description
- Details
- Name
Sets and displays of the symbol style name.
- Description
Sets and displays the description of the symbol style.
- Details
Displays Last saved by and Last saved date.
Symbol
The Symbol tab allows you to set the symbol style.
- Create symbol from
- Setting
- Preview
- Specifies which symbol type is used to create the Symbol style from. You can select several options from the drop-down menu.
- Point object
- Uses a point object as basis for the Symbol style.
- Custom symbol
- Allows you to create a symbol style starting from one of the custom symbols below:
- None
- Dot
- Plus
- X Mark
- Line
- Block
Allows you to create a symbol style from a block in the drawing.
- Settings
Allows you to specify specific characteristics depending on the selected symbol type.
Custom symbol settings
- Preview
- Displays a preview of the specified symbol style.
Display tab
Allows you to specify the display of all symbol components.
- View direction
- Component type characteristics
- View direction
- Specifies for which view direction the display characteristics are modified. Two options are available:
- Plan
- Model
- Specifies the display characteristics of the symbol component.
- Color
Specifies the color of the symbol component.
- Layer
Specifies the layer of the symbol component.
- Linetype
Specifies the linetype of the symbol component.
- Linetype Scale
Specifies the linetype scale of the symbol component.
- Lineweight
Specifies the lineweight of the symbol component.
