Content Browser panel
- Run the CONTENTBROWSEROPEN command.
- Right-click a ribbon panel or toolbar and choose Content Browser from the Panels list.
The Content Browser panel offers you a quick and convenient way to open drawings, manage your block libraries, copy dimension styles, place views for your entire DWG files stored on your computer.
- Add Folder…
- Refresh
- Definitions in the selected drawing
- Local Folders tree
- Definitions’ preview
- Description
Add folder…
Displays the Choose a folder dialog box.
Refresh
Select a drawing and press the Refresh button to expand its content (Blocks, Dimension Styles, Model Views).
Select Blocks/Dimension styles/Model views to see the definitions used within the drawing.
You can drag & drop a block onto the current drawing and an Insert Block dialog box will appear.
You can drag & drop a dimension style into the current drawing. If a dimension style with the same name already exists, a Copy / Paste dialog box will appear.
You can drag & drop a model view into the current drawing. This option is available only in Paper Space.
Local Folders tree
Displays the content of a drawing/project. Right-click menus enable you to add or remove folders from within the Folders tree.
Shows a preview of your drawing/block/dimension style.
Displays a description of your selected definition.
